IGyro 3e questions
IGyro 3e questions
Hi,
I'm sure some of these questions have been asked I just don't have a day to go through this entire site so if someone could help me I would be incredibly grateful. I believe I have everything completely plugged in correctly as I've checked it multiple times. With everything turned on just sitting on the workbench all the lights are green. Okay first off some questions that I just don't seem to be able to find out.
1. Ultimately I want a three position switch for just off and normal flying. Do I have to use the slider first and fly before I can set a three position switch or can you set a slider and a three position switch?
I don't think this would work as there's only one Gain slot in the Gyro?
2. Next question I don't have a GPS sensor so can I make the positions off, normal, and the next mode just for landing to have more gain instead of a GPS ??
3. Last question for now if the Gyro is technically off with a switch or without a switch are the green lights all off?
Anyway please anyone who wants to respond please respond the more replies the better because I'm getting very frustrated the planes on the bench I want to fly it as just sitting there all apart please help me.
Thank you
Thank you
Until you fly the model you don’t know how much gain it will take, so I would set a slider for the gain, zero off in the middle, one way will be rate mode and the other altitude assist (heading hold) depending what model you have, either can work. Heavily loaded airframes fly quite well in HH.
once you have discovered how much gain you can run, you can change to a switch and set the max to just below the % you got to on the slider.
You are unlikely to get more than 50% on a Jet, so pre set the slider atv(travel) to 60% each way.
GPSII is a good unit, but if the airframe you have does not have a silly speed range, you can do without.
Even 20% gain makes a big difference, so anything is going to work for you.
if you have to reverse some of the channels, some green could be red.
I explained a lot of what you're asking in this article, give it a read
iGyro_3e_03_2015_Fly-RC_01.pdf
But yes, adding gyro gain with a mix to the gear down or flap down switch is a common way to kick gyro gain in landing configuration without adding the GPS unit.
