Binding 9303 radio with 2.4 DM9 module .
Please bear with me with this deal as this is my first time in dealing with this situation . I have this JR 9303 transmitter with Spektrum DM 9 module and need to bind to a new Timber Turbo with Spektrum AR 636 receiver . as this is a converted transmitter with new module there are no procedures in the manual . Any help on this will be much appreciated . Thanks !
Thank you very much . I was about to say it didn't have a bind button but then saw the bump on the module and it is the bind button I'm assuming . I bought this used from forum member Papa Jeff and never got any instructions . also this Timber Turbo I'm setting up is my first dsm model , still flying on 72 ! . I will now charge the battery and try it . Do you have to bind everytime you fly or is it once and done ? Thanks .
Binding is done during initial setup.
Unless you leave the bind plug in and put the RX into bind mode by mistake you won't need to bind again.
Yes, there's a button on the module that you press to bind. Hold that button in while powering up the radio and continue until the RX light comes on solid
