Admiral AX600SP DSMX 6 Channel Rec
Can this receiver/gryo be programed by using a JR 9503 radio? I am trying to use the gear switch to be able to turn the gyro on and off. (Admiral AX 600SP DSMX 6 Channel Rec.)
The receiver works with the 9503, however you can not change to any of the 3 modes using the gear switch. You can push the button on the receiver to take it out of stabilization mode and it will fly like a normal receiver. To do that you need to plug the (2) bind plugs into the receiver.
It's channel 5 / Gear port. I went to the mixing page and put in gear but it still does not see it. I went to the monitor page of the tx and move the gear switch and it moving. But for some reason the receiver is not working using the gear or channel 5. I tried another switch or channel and still does not work.....
