The Best RTF Tiny drone with goggles
![Thumbs up](images/icons/icon14.gif)
Makerfire Armor Blue Shark: http://bit.ly/2MEb5EW
Specification:
Quadcopter Size: 8.3*8.3*4.35cm
Box Size: 30*19.5*9.5cm(with Goggles)
Gyro: 6-axis (Hover)
Frequency: 2.4G
Channel: 4CH
Battery: 1s 220mAh 35C (included)
Motor: 615-17000KV 61000rpm
Flying distance: 70m
Transmitter Power: 3 * AAA battery(not included)
Flight time: about 5-6minutes
1000TVL 1/3 CMOS FPV Camera:
Frequency: 5.8G
Wireless channel: 40CH
Output power: 25mW
Operating voltage: 3V-5.5V
Current: 200-340mA
Camera: Sensor: 1/3 "CMOS
Clarity: M7 1000TVL camera
View Angle: 120°FOV H170°
Signal system: NTSC/PAL
Goggles Upgraded:
Size: 138*129*79mm (without antenna)
Weight: 164.7g
Display: 3 inches
Resolution: 800*600 pixels
Antenna Connector: RP-SMA
Working Voltage: 1s Battery (3.7-4.2v)
Working Current: 350-450mA
Receiving Sensitivity: -95dBM
Built-in Battery: 500mAh 3.7V
Working Time: 1h
Features:
1) Built in propeller, more safe flight
2) Built in gyroscope to make aircraft stable
3) 1000TVL camera, real-time transmission of high-definition video
4) FPV first-person view(indoor racing drone)
5) Up / Down / Forward / Backward / Left Turn / Right Turn / Left Fly / Right Fly
6) Rudder speed( high and slow speed)
7) 360° turning, Pattern tumbling
8) One key return, easily recalled
9) Headless mode ,compass headless ,flight with remote control
10) Lithium battery and USB cable with protection
11) Breakthrough conventional wind blades, the flight stability is more powerful
12) With altitude hold, super easy to fly.
Package Included:
1 x Quadcopter
1 x Transmitter
1 x 1S-220mah 35C Battery
1 x Goggles Charging Cable
4 x Blades
1 x Goggles
1 x Straight pole antenna
1 x USB charging cable
2 x Cloth
Unboxing and flight test video by Chris Romano
Specification:
Frequency: 2.4G
Channel: 4CH
Frequency: 5.8G
Output power: 25mW
Current: 200-340mA
Goggles Upgraded:
Weight: 164.7g
Display: 3 inches
Working Time: 1h
Features:
Package Included:
1 x Quadcopter
1 x Transmitter
4 x Blades
1 x Goggles
2 x Cloth
FPV Whoop For Beginners MakerFire Blue Shark by Alishanmao
