New Global ARC MB339 Turbine Ready Jet
My Feedback: (67)
Club promotion: In stock, Brand New Turbine Ready Scale/Sport Jet. Build it in 2 evenings and ready to fly. Rated as the most durable, and easy to fly jets by our club members. 2 color schemes available. Blue - In stock, Red/White: Available in late September.
Price to sell at only $2100 for a PNP (with digital servos, fuel tanks, exhaust pipe, navigation lights, drop tanks, cockpit kit, all installed!) Just drop in your radio and turbine, you are ready to fly in 2 evenings.
Shipping: Free local pick up or ship within USA for $250
Contact me by email: [email protected] or toll free 1-888-573-3883
check it out on Facebook: https://www.facebook.com/10003540963...436176&sfns=mo
GJC would like to introduce to you the next level of Plug n' Play Performance with this Global Aerojet MB-339 Composite Jet! This MB-339 takes PNP to an all new level! Constructed of extremely light and strong Airex Composite material, we are able to ad extreme scale details on the surface with the rivet lines, individual rivets and panel lines. For the first time, a Turbine Ready PNP in this high caliber is available. All the servos, control linkages, hardware are installed and centered right out of the box! Our GJC version includes upgrade servos that are HV Aluminum cased, metal gear Ultra High Torque and High Speed Digital servos that oGlobal Aerojet Seriesut performs the standard package servos by far with better precision, more efficiency and of course much improved strength and reliability! Our MB-339 also includes LED Navigation lights installed and this is exclusive at GJC. Heavy duty electric retract with suspension, beautiful wheels with electric brakes are also installed! The 75oz fuel tank system is also installed and plumbed. Engine is ready for your 80kg to 140kg turbine! If there ever is a so called easiest Jet to fly, the MB-339 would be one of the top choices.
The Aermacchi was designed as a jet trainer and still used for multi aircraft air show displays. The forgiving overall flight performance allows for a wide flight envelope from low and slow to advanced aerobatics tracking like a race car with wings! This MB-339 is available in 3 color scheme choices and has taken all the guess work out of building a turbine aircraft from individual parts. Quick building and more time for flying! You will need your own radio system, avionics batteries, fuel, fueling system and your own choice of Turbine Engine. Get ready for the Global Aerojet MB-339!
Specification:Wingspan1750mm (68.9 in)Length1850mm (72.8 in)Flying Weight(Included 6kg turbine engine & 1350ml fuel)Approx. 9600g (21 lb)Servo7x 28kg & 2x 20kgRetract SystemElectric metal retracts w/ brake systemFuel Tank2000cc (2 liter)Recommended Radio System12 channelRecommended Receiver Battery2x 3S 2000~2600mAh Li-PoRecommended ECU Battery1x 3S 2000~2600mAh Li-PoRecommended Turbine Engine8~12kg (17.6~26.5 lb)
Package Include:
Package Include:
- Airplane (most components preinstalled, some assembly required)
- Scale detailed cockpit
- LED lights
- High voltage coreless aluminum servos
- JP Hobby electric retract system
- Smoke tank
- All-In-One central landing gear control module
- Turbine Waiver required for USA pilots flying in AMA sanctioned sites. Please click here for more details.
- 8~12kg (17.6~26.5 lb) turbine engine (not included)
- 12 channel transmitter and receiver (not included)
- 2x 2S 2000~2600mAh Li-Po battery for the receiver (not included)
- 1x 3S 2000~2600mAh Li-Po battery for turbine engine ECU (not included)
- Battery balance charger and power supply (not included)
- Engine gasoline/diesel/kerosene fuel (not included)
My Feedback: (67)
We don’t offer the plane in ARF Pro configuration. We only sell them in PNP turbine ready that include High voltage GDW digital servos. We buy them in bulk so it’s actually cheaper with all the servos installed. You can chose to replace the servos with your existing servos and use these pre installed servos on other planes.
Thanks. Mike
Thanks. Mike
