Rebel Hot by Comp Arf
Ordered the Rebel Hot. It just so happened the first order of this jet had just arrived in the west coast port. I had the model inside of two weeks.
The model is well made with a complete hardware set.
I purchased the arf plus version. This includes a premounted 60oz tank and retracts and pipe.
The paint is nicely done in the mould. The Rebel graphic on the fuse is cut vinyl.
That looks really nice Bob.
What you powering it with ?
Some more pics would be nice.
I will post more photos when I start assembly. The retract system is made by JP the gear feature is 65 mm main wheels so grass operation will not be an issue. Four of my five jet models have the JP landing gear and they have been flawless in operation.
Power will be the new X 45.
Nice!
Look forward to seeing pics from the build.
Looks to be a perfect fill and fly type model (the type I like )
I have one on its way, should arrive any day, I have a xicoy 45 in a sebart mini avanti, did consider using this but I am not to sure if that enough for the grass when its spring / late summer when its not really short, thinking of a 70 size ?
My Feedback: (21)
Bob, you beat me by one day. Picked up mine this afternoon after work at the post office. Looks to be built with the same construction detail as other Comp ARF jets that I have, Looking forward to watching pictures from your build. Mine will be a late fall early winter build. Do have a question, did you get any build paper work with yours? You know control surface throws and CG. None in my box, I’ve reached out to Andy and he is looking into build information.
Robert
Robert
Robert
Robert
NONE. Waiting to hear back from Ray.
Thank you
