YPG HV-120A ESC 4S~14S SBEC Brushless Speed Controller / ESC
Removed from a Helicopter that was Never Flown. This one has its Programming Card and you can see how to program it on videos on the Internet.
PayPal or USPS Money Order
$6.95 Shipping Priority Mail
All YPG ESCs can be programmed via optional programing card or by transmitter stick inputs.
Features:• HV capability for use with up to 14S (51.8V) Lipoly
• Optional programming card for convenient setup
• ESC had separate programming lead built-in so there is no need to unplug from RX
• Super fine throttle resolution provides first-rate and highly accurate linearity
• Super smooth adjustable start-up mode
• Constant RPM mode (governor mode)
• Adjustable F3A brake.
• 3 steps adjustable normal EMF brake
• High anti-interference capability
• Low voltage cut-off protection with automatic adjustment for NiCd/NiMH/Li-Ion/LiPo/LiFePO4
• Soft cut-off option at low voltage, slows motor RPM gradual rather than hard cutoff (LVC)
• Low voltage cut-off can be disabled
• Variable cut-off voltage / cell
• Active free-wheeling circuit allows for unlimited "partial load" capability
• LED status display
• Adjustable motor timing from 0° to 30°
• Blocked rotation protection (senses a jammed motor and stops motor rotation)
• Motor reversing from ESC (no need to change ESC/motor wires)
• Over-temperature protection and overload alarm
• Anti sparking circuit: reduces connection sparks
• Throttle signal lose protection. If the signal is lost for 3 seconds, the power will automatically cut-off.
• Safe power-on. (Motor will not start until throttle is returned to lowest position)
***This ESC is compatible with both helicopter and airplane models.***Specification:
1.Max Cont Current: 120A
2.Max Burst Current: 140A for 10 seconds
3.Input Voltage: 4-14 cells li-XX or 12-42 Ni-MH/Ni-Cd battery
4.BEC: None (OPTO)
5.PWM: 8~16 KHz
6.Max RPM: 240,000rpm for 2 Poles Brushless Motor
7.PCB Size: 68x53mm
8.Weight: 164g (including wires)
BEC: None (OPTO)
PWM: 8~16 KHz Max RPM: 240,000rpm for 2 Poles
Brushless Motor PCB Size: 68x53mm
4.BEC: None (OPTO)
5.PWM: 8~16 KHz
7.PCB Size: 68x53mm
BEC: None (OPTO)
