Rustler Grinding Noise
Hi everyone, I picked up my 2wd Rustler VXL from my basement and when i went to drive, a very loud grinding came from the gearbox. I was missing a slipper pad so I replaced that. Same problem. My Back plate screws were crossthreaded so i replaced them, still same problem, then i tried to fix the mesh many times and still nothing. Any help would be appreciated. EDIT* My spur is also slightly stripped, im not sure if that would be a factor.* SOLVED: Spur was too stripped.
