Help with SCX 24
Help with SCX 24
I have the SCX 24 (Jeep) witch has the AE-6 ESC. The vehicle worked for the first battery charge now when I turn it on it only has power to the steering. Forward and Reverse are unresponsive. I cant seem to find how to re-calibrate the ESC. I found the directions for the AE-2 and tried it but did not fix the problem (Turn on Receiver with throttle to the rear, turn on ESC). The ESC light will blink red when I turn it on. When I try to re-calibrate I turn on the truck and the wheels will work for about 3 seconds. Any help would be appreciated.
Help
pn 130 70q ? Where can I get that for mine !! I’m having the same issue too
where can I get what you got and not deal with axial going back and forth with this ?
send over the link of the stuff you got please I’ll just replace it ☺️ Thank you !!
Scx24
Scx24 help
Hi not sure what happened. I answered your question. But it didn't post. You need to go to Kenon hobby it's the pn racing 70t 130 motor. 14$
from shapeways you'll need the v1 and v2 plates for transmission. They are made by gamey I think. The plates allow for the bigger motor. One is for speed allows a larger pinion. The v2 is for crawling. It faces the motor forward. About 15$, you'll also need a pinion as the stock one is to small for motor shaft. I have a bunch. So if you need one I'll put in envelope and send no charge. Hope this helps if you have any questions just ask. Good building
I'm unable to post pics as I'm a new member will try to finish the 10 post minimum today and post pictures of my build.
