Oxygene
Old 03-30-2020, 06:50 AM
papaone
papaone's Avatar
Default Oxygene
Hello
New plane designed by Arnaud Poyet member french F3A Team and built by Hui Yang.
Awesome design.
https://www.facebook.com/oxygenF3A/?__tn__=HHH-R
https://www.hobbynet-jp.com/?pid=149523540
claude
Old 04-17-2020, 03:00 AM
papaone
papaone's Avatar
Hello
Arnaud Poyet designer of this plane received his.
Old 04-17-2020, 07:56 AM
Ricardo M.
Oxygene and Akuma + seems to be very similar, if not the same, model.
Old 04-17-2020, 11:12 PM
Sasha doctor
Beautiful plane. How are flight this model?
Old 04-18-2020, 01:34 PM
Arnaud POYET
Hi,
With containment, I haven't been able to fly yet.
It is an evolution of my Elixir, of which I am not worried.
I'll keep you posted when it has flown.
Best regards.
Arnaud
Old 04-20-2020, 09:42 AM
Flowmotion
__________________
Ricardo Mendez Turell
In fact, both models look extremely similar. There are only very slight differences. The basic interpretation seems very similar.
But I think both designs are really great.
Greetings
Gerhard
Old 04-20-2020, 02:39 PM
Ricardo M.
Greetings
Gerhard
Both models are gorgeous, for sure.
The following 2 users liked this post by Ricardo M.:
ajay1 (09-15-2020), wattsup (04-20-2020)
Old 09-15-2020, 08:21 PM
ajay1
I just received my "Oxygen" from Aerobertics --
Should I set the Tail at "0" degrees and wing also at "0" degrees" Incidence?
Old 09-16-2020, 07:14 AM
Ricardo M.
Usually 0° stab and 0.5-1.0° wing
Old 09-16-2020, 10:06 AM
ini
I would say normally wing 0.5 - 0.7 degrees positive, stab @ zero.
​​​​​​Motor 0.5 - 2.0 degrees negative depending on plane and preferences.
If plane is on the heavy side and/or wing area is small maybe 1.0 degree is needed.
Old 09-16-2020, 10:38 AM
Arnaud POYET
Hello,
My current setup is stab at 0°, wing at 0,8°.
For the datum line, the canopy is exactly at -3°.
Best regards.
Name:	Capture d’écran 2020-09-16 à 20.36.14.png
Old 04-04-2023, 10:53 AM
Jokre
Hello,
I have a question about the center of gravity/ C.G. for the Super Oxygen
There are very different informations:
Oxygen : 270 mm
Website F3a unlimited and Aerobertics for the Super Oxygen: 274 mm
Website Hui Yang for the Super Oxygen: 320 mm !
These are already very big differences between the information of the website of Hui Yang and the others.
Which one is the right, does anybody knows the right CG?
Thank you very much.
Best regards
Jochen
Old 04-04-2023, 10:37 PM
Arnaud POYET
Hello,
I use a C.G. around 320mm, which is 36%.
You can start at 320mm and then adjust later by doing flight tests.
Best regards.
Name:	Centrage super OXY 36%.png
Old 04-05-2023, 04:15 AM
Jokre
Hello Arnaud,
thank you for the quick answer, thats how I try it.
Are the other settinges for the Super Oxygen unchanged to the former Oxygen?
stab at 0°, wing at 0,8°, Adverrun contra at 0°.
Did I measure correct, the fuselage front ist – 1 °.
Best regards
Jochen
Old 04-05-2023, 05:02 AM
Arnaud POYET
Hello,
Yes, stab 0°, wing 0,7 to 0,8° and adverrun at 0°.
For down thrust, noise is -1°, I put a little more. Around -2°.
Best regards.
Arnaud.
Old 05-27-2024, 07:54 PM
FBW
Just wondering.....
Is the downthrust mentioned above relative to the stab or the thrustlne of the airframe...??
Old 06-08-2024, 08:42 PM
FBW
Originally Posted by FBW
Just wondering.....
Is this a silly question too hard or a well guarded secret.........Sorry I am new to this
Old 06-08-2024, 09:27 PM
drac1
drac1's Avatar
Incidences and thrust angles are all relative to the datum line of the aircraft. If you don't know where the datum line is, set up the plane on the bench with the wings at whatever the incidence is. 0 degrees is then your datum for thrust angle.
Old 06-10-2024, 07:02 PM
FBW
Thanks for the reply drac1....
Am I correct in saying that when the gentleman above says Adverun at 0 deg he means relative to the nose ring ...
Old 06-10-2024, 07:20 PM
drac1
drac1's Avatar
Not really sure what that means, the nose ring is usually set to the down thrust angle.
Old 06-15-2024, 06:12 PM
FBW
Ok let me ask this in a different way...
If the airframe has a build in down thrust of negative one degree relative to the theoretical thrust line and the wing is set at positive .8 degrees relative to this line....does the airframe now have a down thrust of 1.8 degrees or is it still 1.0 degrees .
Old 06-15-2024, 11:08 PM
drac1
drac1's Avatar
Everything is relative to the datum/thrust line.
Ask yourself this. Is the wing incidence the datum line?
Old 06-17-2024, 06:55 PM
FBW
I don't know is it....??
When you buy a new airframe is the wing set zero degrees to this datum / thrust line ??
Old 06-17-2024, 08:47 PM
drac1
drac1's Avatar
See #18
Old 07-31-2024, 04:29 AM
Taak
Hi!
I am tentatively interested in this plane. Can someone please tell me how it flies compared to other modern F3A monoplanes? Is the fuselage so high that it is difficult to see the position of the wings? How does the plane fly compared to modern F3A biplanes? Does the swept wing design help with integrated rolls? ​
