Reversing Y Harnesses
A customer came into the Hobbyshop where I'm working looking for a reverse servo to use on the elevator of a Foam EDF. Not stocking much in the line of reverse servos I asked why he didn't use a y harness with a reverser. He informed my that Spektrum advises not to use them. This surprised me as I'm currently flying 2 aircraft with them installed. The only thing I noticed using the reverser instead of mixing is one elevator is a little slower than the other. It's only noticeable if you slam the elevator stick. The airplane flies fine.
Anyone know the reason that Spektrum doesn't recommend the use of a reversing Y harness.
They also may not have the same "center" position as the receiver. Early Spektrum receivers used the same 1520 microsecond center that JR receivers used in both the FM and DSM products. Newer Spektrum designs use 1500 microseconds.
Was it not possible for the guy to use the other side of the servo output arm for his installation?
Andy
Ive used them in flaps on jets where servo tracking speeds is not an issue as I slow them down anyways and activate on base final turn. What I did notice and these where with the EXPERT brand, (a JR private label,) was that outside temperature differences required me to adjust the centering pot provided. I concur having used them they have there shortcomings.
Many years ago Futaba made an item called an SR-10, which had a single line input and 2 outputs.
One of these was normal direction, but the second was reversed with an adjustable neutral via a small pot on the top of the case.
They cured the delay by having the input signal buffered before having anything done with it,
Then the 2 outputs were also sync'd together and no timing issues occurred.
There are still some around if you can find them.
modtron
Oxford UK
modtron
Oxford UK
My Feedback: (25)
Those Futaba ST-10 units worked perfectly. Unfortunately they discontinued them, I suspect because with the bigger radios the two servos could be put on different channels and synchronized that way. But not everyone can afford a transmitter that does that I guess.
I lucked into on SR-10 at a swap meet last year for $20. I hope I can keep finding them. The reversers you order on the I-net suck. Most of them don't have a pot for centering the second servo and the ones I have used induced a lot of jitter in that servo.
modtron
Oxford UK
modtron
Oxford UK
