Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
20cc Profile Edge 540 Build
Old 06-03-2020, 03:22 PM
Steve
My Feedback: (54)
Steve's Avatar
Default 20cc Profile Edge 540 Build
I've been building a 20cc profile over on GSN and thought I'd share it over here as well.
Elevator and Stab sheet ready.
Old 06-04-2020, 04:28 PM
Steve
My Feedback: (54)
Steve's Avatar
The rudder.
Old 06-04-2020, 04:33 PM
Steve
My Feedback: (54)
Steve's Avatar
fuse nose
Old 06-05-2020, 06:48 AM
Steve
My Feedback: (54)
Steve's Avatar
Basic fuse assembly.
Old 06-05-2020, 03:44 PM
Steve
My Feedback: (54)
Steve's Avatar
Fin glued.
Old 06-06-2020, 07:18 AM
daveopam
My Feedback: (9)
daveopam's Avatar
You do good work. If i may make a small suggestion without offending. On flat control surfaces I like to make a tiny holy in the hinge line to let the gasses out when you cover. That can be done later with a T pin, but putting a pin hole through your cross braces now will allow the gas to escape when shrinking the covering with only one exit hole in the hinge line.
David
Old 06-06-2020, 09:15 AM
Steve
My Feedback: (54)
Steve's Avatar
David
Excellent suggestion, thanks!! I'll do the t-pin holes in them now. Covering is not my strong suit.
Old 06-06-2020, 09:20 AM
Steve
My Feedback: (54)
Steve's Avatar
Here's a couple of the fuse about complete. I went ahead and added a tank mount, instead of installing
the tank inside the fuse. I also put the throttle servo in the wrong spot and had to move it down some.
Old 06-07-2020, 03:40 PM
Steve
My Feedback: (54)
Steve's Avatar
Using an old set of Pro X 260 landing gear.
Old 06-07-2020, 03:44 PM
Steve
My Feedback: (54)
Steve's Avatar
wing panels next
Old 06-10-2020, 02:48 PM
Steve
My Feedback: (54)
Steve's Avatar
Had to kind of figure out how I wanted to assemble the wing panels and what holes were going to be needed Also made some tube supports out of 1/8" ply.
Old 06-10-2020, 02:52 PM
Steve
My Feedback: (54)
Steve's Avatar
Once I got both wing panels done, I glued in the tubes using the fuselage to make sure I had proper alignment.
Old 06-11-2020, 11:44 AM
daveopam
My Feedback: (9)
daveopam's Avatar
If you have not sheeted the other part of the wing. I would box in the servo opening and not just have the rails running parallel to the spars. This will make it stronger and make it easier to cover. I might even suggest moving the servo closer to one of the ribs for strength. Larger models were lost to flutter from not doing it that way.
david
Old 06-11-2020, 01:16 PM
Steve
My Feedback: (54)
Steve's Avatar
david
Thanks for the heads up David, but I've already got it covered. It's the same as my AeroWorks Por X 260 that I've flown for years now.
Old 06-12-2020, 06:44 AM
daveopam
My Feedback: (9)
daveopam's Avatar
I am anxious to hear your flight report on it. My current profile is a 72" OMP Fusion. It's under powered with the DLE 20cc. The previous one I had was the 67" OMP Fusion. The 72" is a sturdier airframe but it's a lot heavier. It's going to need a 26cc from Valley view RC and then I'll "need" a airframe for the 20cc.
Keep up the good work, David
Old 06-12-2020, 07:26 AM
Steve
My Feedback: (54)
Steve's Avatar
I hear ya! I'm currently flying an Aero-Works Pro X 260 with a DLE 20. It's a bit on the heavy side, but I can climb out of hovers ok. This plane should come in around the 7 lb mark, and no problem for a DLE 20. I'm also flying a U-Can-Do 60 with a DLE 20, at 9 lbs. It struggles to pull out of hovers. I think a VV 26 would be a good engine for that one. And thanks for the positive support!! Always appreciated.
daveopam (06-13-2020)
Old 07-27-2023, 10:48 AM
RKSHSHY
Default Regarding edge 540 20cc plan
dear sir . I am rakesh sahay from india . I saw your post for edge 540 for 20 cc model can u provide me a pdf or cad file.
Old 10-25-2023, 07:44 PM
giantscalercguy
David
Jesus, I think this guy knows how to do Monokote
