Super Tigre .56 Saturno
Need some help with my Super Tigre Saturno .56. Very old engines that I like working with. One of mine has two piston rings, another has only one. Why were two needed?
I broke the top ring on the dual ringed piston while reassembling the engine.. The engine still "pops" with compression. Where can I find a replacement ring? I tried to look up the
definition of "pinned" ring and "Dyke's" ring to no avail. What type is used on this engine?
Another problem occurs as the crankshaft minutely clicks back and forth after tightening the prop nut. The coned washer behind the prop plate is supposed to hold the crank in place. Also, I can see the front bearing move outward as the crank moves. The bearing won't stay affix to the case.
I never found out why some engines have two piston rings but I did get a replacement and installed it.
