UMS 7/260CC radial engine with Biela 30.5x13 3Blade good deal w/free airshipping
This is new engine run on the bench for 20 mins only with the prop, originally planned to fit 3M Sports plane, found the engine is too big to fit in. The engine still has the orignal packing box. Prop Biela 30.5x13 drilled, so, no extra work to fix the propeller. for the combo deal, $600 USD saved. Combo package with the prop and freight $2999 USD.
Only the engine $2800 USD
Our Paypal address
[email protected]
whatsapp: 00610433000015
SPECIFICATION
Type SPARK IGNITION Cylinder Type 7(ABC TYPE) Bore 35.7MM Stroke 37MM RPM Range 1000-5500 Weight of Engine 6700g incl.(ignition coil & silencer) Engine Diameter 320MM Length 215MM Prop Range 32X12,32X14,32X18 Muffler Type COLLECTOR RING Plug Type CM-6 Carburetor WT 621 Power 15.6 Tank Capacity 260CCwithout propeller $2800 USD with free air shipping
