Concave sanding tools?
I have the multiple shape sanding tools. I want to use the 1/4" radius feature. I also have the sticky backed sandpaper, but it doesn't work very well with the tool. Any other suggestions? Is there a way to make this work I don't know about? TIA.
My Feedback: (9)
Carl Goldberg used to include one with their Ultimate biplane. I think I still have one I see if I can find and post a picture. It was just two pieces of flat ply and a U shaped bracket for each end you glued the flat pieces to. Then stuck the paper on. They work pretty good. Overall it ends up about 4" long and 1-1/4" square. Every kit had one, maybe someone close to you has one.
David
David
You can easily make a selection of concave sanding tools out of short lengths of PVC (or other material) pipe.
I've made a number of them using pipe of different diameters (PVC works best and is easy to cut).
Simply cut to desired length...you might want some long (like for leading edges), or short for utility work.
Next cut in half, quarters, or even thirds lengthwise..
Use sticky-back sandpaper of the grit appropriate for the task.
Bonus: If you wanted to sand a concave surface on the plane then just put the sandpaper on the outside of the piece of pipe.
Cheers,
G42
Cheers,
G42
daveopam (08-17-2020)
Here is a sample of a convex sander. Cut in 2 lengthwise and you can make a concave sander. I also use the plastic cover from caulk tubes. Smaller diameter is doable. You just have to find the right size tube.
