Fancy sharing pics of your Jet storage racks/ trollys?
I need to make a portable storage rack to store my jets one on top of another. Something either out of wood or metal and with wheels that I can easily move about the workshop.
I know some have done this but I can’t find any pics.
Jason
Jason
https://www.robotunits.com/en-us/pro...ng-technology/
They can be purchased in standard lengths and cut yourself or ordered to exact cut lengths if you soecify
You design it yourself and assembly is simply a sliding T nut secured by a single socket hex head bolt
Infinitely adjustable and scalable
Very lightweight and strong
You just sketch out what you like order the aluminum and bolt it together.
I can post some part numbers that I used to help
bidrseed2 (12-09-2020)
https://www.harborfreight.com/bicycle-lift-95803.html they actually $10.99 right now and they can lift easily all my jets up to 70 lbs
You guys have given me some good ideas!!
My Feedback: (26)
This is what I came up with when I bought my new trailer. Racks are made out of 2 x 2 x 1/8 steel angle. There are 4 blocks attached to the wall that lock the racks into position and a heavy ratchet strap holds them to the wall. There are holes drilled in the uprights so I can change the shelf height as needed when the inventory changes. When its time to work on one of the planes I just roll the rack into the garage. Since my trailer is long enough if I'm out at the field and the weather gets nasty or I just want to pick up for the night at a fly in all my planes except for the Viperjet (WS wider than trailer) can be put in the racks with the wings on and both racks can be rolled into the trailer end to end.
