PHT3 Fod Guess Query
PHT3 Fod Guard Query
Hi folks,
I recently acquired a secondhand PHT3 and noticed there is no fod guard on it .Should the PHT3 have a fod guard ? If yes any idea where I can buy one and is some disassembly required to install ? Thanks
Yes, there should be a wire mesh over the intake.
It is not a user fitted item.
It will need to be returned to JetCat in Germany for fitting as it will requires the turbine to be removed from the mechanics and then realigned under load when being re-fitted.
modtron
Oxford UK
modtron
Oxford UK
Chopper-Man-Mike (12-08-2020)
