Rotary Tool Dremel Accessory Kit 228 PC | Grinding Sanding Polishing
I have a few sets of these
Quantity: 223pcs
Shank diameter: 1/8" (3.175mm)
Application: Mainly used for DIY carving sanding, cutting, polishing / wood, metal, mold polishing.
Item Quantity (pcs)
1/2" x 1/2" Sanding Bands 20
1/2" x 1/4" Sanding Bands 20
Mounted Abrasive Stones 15
1/2" x 1/2" Mounted Rubber Mandrels for Sanding Bands 1
1/2" x 1/4" Mounted Rubber Mandrels for Sanding Bands 1
7/8" Rubber Polishing Wheel 2
3/4" Pink Aluminum Oxide Wheel 6
3/4" Green Aluminum Oxide Wheel 6
Stainless Steel Brush (7/8", 3/4",1/4" ) 3
Nylon Wire Brush (7/8", 3/4",1/4" ) 3
Copper Wire Brush 3
Fiber Glass 1 1/4" Cut-Off Wheels 10
1" Soft Polishing Woolen Wheels 15
1/2" Soft Polishing Woolen Wheels 30
3/8" Hard Polishing Woolen Points 10
Silicon Cut-Off Wheels 35
1" Aluminum OxidebCut-Off Wheels 30
Diamond Burrs 5
HSS Burrs/Drills 6
Polishing Paste 1
Wood Storage Box 1
Total 223pcs
$30 shipped
Quantity: 223pcs
Item Quantity (pcs)
Copper Wire Brush 3
Diamond Burrs 5
HSS Burrs/Drills 6
Polishing Paste 1
Wood Storage Box 1
Total 223pcs
$30 shipped
