rebuild old buggy
Old 01-22-2021, 01:31 PM
DRO55
Default rebuild old buggy
years ago i built a kyosho turbo ultima. went thru a divorce and apparently x did not like my car. ripped all wires out. is it rebuildable. if so what would you recommend.
Old 01-22-2021, 08:38 PM
bill_delong
bill_delong's Avatar
re-wiring a car should be fairly easy, though if they were cut at the case opening then you might have break it open and re-solder fresh wires on the internal board... if your soldering skills aren't up to par then it might be easier to replace the electronics at that point.
Old 01-23-2021, 05:20 AM
DRO55
thanks for the reply i thank that is above my skills to replace what would recommend radio motor speed controller batterie and charger i think i would need could i use the same servo for steering reading a bit i see there's a motor and speed controller together would that work
Old 01-23-2021, 06:43 AM
bill_delong
the options to consider out there are endless, I'm sure you can probably find a better deal, but for peace of mind, I would recommend HobbyWing for the ESC and then you can cut corners everywhere else:
ESC: HW EZRun Max10
Motor: HobbyStar 3560-3300KV --> this is a mild brushless motor which is better suited for dated buggy designs before powerful brushless systems were introduced
Battery: HobbyStar 2S-30C-5.2Ah --> not 100% sure if this battery will fit, double check battery tray measurements first!
Servo: Which servo is right for me?--> I would get the JX PDI-4409 if it were me, also buy a spare just in case you strip any gears.
Charger: Which charger is the best? --> iCharger X6 or S6, these are best balance between price/performance/quality you can get
Radio: Which surface radio system is the best? --> I would get the Hobby Porter HP-007, most features for the price!
Note that I went cheap where possible, but chose quality where it counts
Good Luck!
Old 01-23-2021, 11:06 AM
DRO55
do too you are the olney one answering do you mind more question
Old 01-23-2021, 07:35 PM
bill_delong
sure, go ahead!
Old 01-24-2021, 10:14 AM
DRO55
looks like you need a good job to be an r/c enthusiast. motor looks small how much run time. how about this
Hobbywing QuicRun Fusion Brushless System Motor & ESC 2-in-1 1200Kv / 1800Kv 540 Waterproof
or this
Hobby Wing 38010203 Max10 ESC, with 3652SL Brushless Motor - Combo (3300Kv)
as you see i am a nuwbbeee and not plenty of money. i liked you went with. i guess i need to study more
thank for speaking with me
DRO55
Old 01-24-2021, 01:46 PM
bill_delong
If you want to get a combo deal then yes this one here would be good:
https://www.hobbywingdirect.com/coll...nt=27757683857
"COMBO-A MAX10-3652SL-3300KV"
It will have more torque than the motor I recommended originally, so be sure to program the ESC from LEVEL 5 punch default to level 1 punch (lowest) setting and also adjust your throttle expo to -25% to help soften the throttle so you'll be less likely to tear up the drive train.
