P20 sx no pump
MI
P20 sx no pump
Worked ok last year. No fuel while priming.
now no pump!
Plug in system as normal.
Valve clicks and pump runs w/o startup sequence????
Should not be running yet!
Programing problem????
Weird!!!
Any ideas????
Dave
now no pump!
Weird!!!
Any ideas????
Dave
The P-20 pump is small if the gears were stuck you can fry the electronics. Anything smells 'smoked'?
You are saying the pump does run and prime fuel?
Try a system reset to clear all the logs
