Carf j10 with Kingtech 210
Awesome flying jet that hovers. Everything was brand new when I but it together. Kingtech 210 with 264 minutes that restarts if it flames out. Has savok 2274s throughout. Mercury powerbox with gyro and GPS speed sensor. One flight front landing gear had a leak and scratched the front nose ( see picture) after that I changes to all electric beotec gear and struts. Still has air brakes as the electric brakes i think added too much weight. Weights about 27 pds. Smoke tank from CARF with powerbox smoke pump. Everything was built per CARF specs. Never crashed. Full thrust vectoring. Had detail shop make all the decals. Comes with 2 a123 receiver batteries and 1 a123 for turbine. 1 lipo for retracts. Is perfectly balanced just add your receiver and go. Local pick up only
Call or txt
Justin
618 365 7726
Call or txt
Justin
618 365 7726
