kingtech telemetry powerbox jeti
Hey guys trying to figure out the kingtech telemetry..so l have a jeti ds16 radio in the plane l have a powerbox royal..in the set up when l pick jeti an hit the next button it switches to futaba an won't stay on jeti..if l hit the next button again it goes to tank size an goes through the rest of the set up but won't read on the radio what am l missing or what do l have to change or will this not work with the telemetry going into power box an out..
Kingtech telemetry have to be connected to one of the telemetry ports on your Jeti receiver.
your Powerbox will not work as a telemetry “hub” for Jeti.
signal from Between Jeti transmitter and receiver is bi-directional. Signal from Jeti -> Powerbox is “one way only”.
