DLE 85 Hub Removal
DLE 85 Hub Removal
Prop bolts got sheared off, I got lazy and didn't check the bolts and the wood compressed and the bolts got loose. Trying to remove the hub to replace it. On the DLE 55 it's easy, theres a little flange on there I can just use my pullers, and it pops right off. On the 85, no flange, just straight down to the crankcase. I've removed the two set screws. The thing just won't come off. I even put a torch to it to warm it up a bit. No joy. Am I missing something, is there a trick to this? I reall don't want to damage the crankcase or sensor, any ideas?
How many of the bolts are sheared? It may be possible to back the broken bolts out without removing the hub.If you have access to a machinist they should be able to help you.
Good luck
Tas
Good luck
Tas
There is a prop drive hub nut that has to be removed. Look straight down the center of the hub you will see the nut on the shaft. you will need a deep socket to remove it. See parts link, it's item # 2 page # 22. http://manuals.hobbico.com/dle/dleg0085-manual.pdf Here is some good info on removing the hub nut. https://www.flyinggiants.com/forums/...d.php?t=220860
As you can see in the photo, they are all sheared at the hub, so no gripping them.
There is a prop drive hub nut that has to be removed. Look straight down the center of the hub you will see the nut on the shaft. you will need a deep socket to remove it. See parts link, it's item # 2 page # 22. dleg0085-manual.pdf Here is some good info on removing the hub nut. https://www.flyinggiants.com/forums/...d.php?t=220860
I really didn't want to have to take off the engine and go thru all that drama, but if I cant find pully pullers to fit between the hub and the crank case, I'm going to have to find someone who can drill in some anti thread screws so I can screw them out, or disassemble the engine to some degree and stick it in the oven. Even then, no guarantees so I was just wondering if anybody had some cool trick before I went old school.
Finally got it. I just put the torch on it a little bit longer at a low setting, and went around the entire thing so as to even out the heat. It eventually popped free with a tiny bit pressure from a really wide blade flathead screwdriver.
Whew!
Whew!
The bolts are most likely too hard to drill out anyway. Unless they are locktited in a little careful work with a Dremel and either a diamond or carbide burr should cut a slot or ledge to enable them to be backed out.
Tas
Tas
I thought about that, but after the heat, I wouldnt have good faith in the magnets performance, it's most likely compromised. I'm gonna test it, but first see if I can even get the volts out just for kicks.
My Feedback: (19)
I know a sometimes controversial subject. But prop bolts are a maintenance item that need to be checked from time to time. When people use loctite, they tend to not check them thinking they will stay tight. Then the prop compresses over time leaving the bolts holding little compression on the prop hub ..... then they break. Its a predictable cycle. I have never seen a prop bolt come loose if it was still holding compression on the prop hub. I just use hardened flat washers between the bolts and the prop hub washer. I replace the original bolts if their grade is not known.
