BackCountryRC F16
BackCountryRC F16
This F16 is a modified chuck glider from BackCountryRC. It uses newbee drone unicorn motors with a Y lead soldered to the ESC (which is in turn integrated into a 4ch Spektrum compatible receiver), a 300 1s battery with a Ph2.0 connector (3:20 flight), and two 1.7g servos. For optimal performance, the CG should be set fairly far forward, with a decent amount of reflex on the tailerons (there is not a huge amount of excess power so you really want to be moving through the air with as little AoA as possible). The model is fairly quick for its size and tracks well, although some care must be taken in turns, as it has a tendency to dive mid maneuver. If you are interested I may be able to send you a copy of the transmitter settings.
The price is somewhat negotiable but bear in mind that this is a nearly new scratch-built airplane, and is being sold more or less at cost.
