Jetcat U-Idle setting change?
I am trying to change my P60SE to a Flightworks 200 pump. The FW pump requires slightly more voltage than the stock pump. By changing the Acell 1 and Acell 2 I can get the engine to ramp properly and it peaks at about 53K (idle is 50K). However when the engine rolls back to idle, it rolls back too much, underspeeds and shuts down. The U-Idle is set at .4 ( pump starts at .5)and needs to come up a touch to compensate for the new pump. I looked through the GCU and software, but cannot figure out how to change this setting.
V6.0 software
Any ideas? Is this one of the settings that is passcode protected?
Thanks!
-Dave
V6.0 software
Thanks!
-Dave
I do no want/need higher idle. Engine runs fine at 50K. The issue is that after the ECU come off the Accel2 Ramp, it heads back to the .4 U_Idle , which is too low for this pump. If I can figure out how to change U-Idle, it should be fine.
I would assume the U-Idle can be changed via the PC interface. If somebody has the code to change the pump parameters, could you PM me?
-Dave
-Dave
