Gas solenoid source
AR
Gas solenoid source
I’m having a problem with a gas solenoid on my Wren Supersport. It works some starts but during others, it sticks closed and will open if I beat on it with a screwdriver. When it does function, the starting EGT is being exceeded. Not sure if both problems are related. Does anyone know where I can find a Jet Tronics gas valve that is compatible with this engine? I can not find one.
thank you,
Cody
thank you,
Cody
AR
Part of if not all of my problem was an ECU batt that showed charged voltage but couldn’t handle a load. Went to a new bigger battery and starts are normal temps and the solenoid worked every time. I monitored the solenoid with a stethoscope before doing a full start and it worked ever time.
AR
Thank you Cars. I have been operating this engine for 10 years and I had no idea about lubing the valves. I have been operating LiPos for much longer and just got an education on how a $20 batt can fall on its arse and cause problems.
