Brakes Q & A
Brakes Q & A
Folks,
after some info on brake systems. Not for a jet but a large 35kg Cessna. As you jet folks use brakes the most thought you would be most knowledgeable.
Hoping to fit them to the existing Sullivan Skylite 7" wheels.
Pros / cons of pneumatic vs electric
Which company is best and why?
How are you controlling them on your Tx? Slider, rotary knob or . . . ?
thanks in advance
cheers
me
thanks in advance
cheers
me
Air requires more items and can leak, I would recommend electric this day in time. I use a slider on my radio some put in a mix with full up down elevator to action their brakes.
The new electric brake controllers also have gyro stabilized braking which is fantastic on models
Just my opinions and thoughts of course
Electric 100%. Fitting them to an existing Sullivan wheel is doable, but will take some engineering. Put them on a slider that you can access while still flying the airplane.
thanks guys appreciate the input. I do like the idea of electric. Electron retracts has a 5" set of electric disc brakes. Not sure if theirs have a gyro or not but they think that can be made to fit my wheels.
any recommendations for the electric brakes?
cheers
cheers
My Feedback: (53)
I had to setup brake on a European Turbo Prop plane ˝ scale…..(we have to have brake but not the European) so I got the a set of wheels and brake from Electron, and their small and inexpensive brake controller, it doesn’t have a gyro, but got something that’s like ABS it pulse….there’s different setup, my brake are on the right end slider….
Skunkwrks (12-06-2022)
My Feedback: (41)
It's too bad Greg doesn't have a website for the Electron stuff, he's just into so many different things RC I imagine maintaining a bunch of websites would be spendy. I think he's got a Facebook page but I don't go there. He's got a heli, operation as well as a Turbine operation along with the Electron stuff.
JMHO......
Electron's policy is to use their stuff exclusively or the warranty is void and we will not support you. Xicoy designed and makes their gear controllers. The Xicoy LGC-15 and Electron GS-200 are the same thing, but the LGC-15 is unlocked and can be programmed to work as needed. I ask Electron for the settings so I could program a LGC-15 for a set of Electron gear and the factory would not tell me the values and suggested that I get their controller instead. I get that they want the users to have success with their products and don't want warranty claims -
So, if you get Electron wheels and brakes and you don't mind spending an extra $100, get the GS-200 and all will be good and you'll have a warranty.
My Feedback: (53)
Second perhaps it’s in the way you asked…because I got value for the electron no problem at all……and he’s just doing brakes so there no value to be had
The LGC-15 you buy as an individual should all be unlocked, if not its an easy fix. LGC-15 is different than the basic electron controller, but the 200 are pretty much the same.
