Need help identifying airplane, SBEC and speed control
My Feedback: (22)
I recently found a used pattern plane in the back room of a local hobby store and had to have it (tired of buying foamies). The plane seams to be fiberglass fuse with foam core balsa sheeted wings. Found a makers label inside that says CPLR. It's about 78" long from spinner to end of rudder, and a wingspan of 72". It has a JETI model SBEC 40 and a Hacker speed control.
Looking to ID the plane and some specs. Also what Lipo batteries I can run in it. I was told a 3s or 4s by the store owner but he didn't know ANYTHING else about it and the SBEC.
Hello
I'm not sure maybe a Synergie which is the plane designed after the Alliance.
The front of the Alliance is rounded and that of the Synergy has two edges.
It is a 2 X 2 and therefore flies with 10 S batteries.
The appropriate controller is minimum for example Jeti Master Mezon 95 up to Mezon 130
http://www.gbrcaa.org/ntoa/ZN%20Synergy%20Part%20I.htm
Claude
Claude
