Purchased an airframe with an almost new DLE170 installed on it......less then 5 minutes of run time to check out the installation by the original owner.....you can see there's no fouling of the internals, nor color change in the surfaces normally heated when run for longer
I have the short, short video of the actual running of the motor if interested. Exhaust tubes cut short for installation.....if they're too short new ones can be purchased from any DLE dealer at minimum cost.
I'm going in a different direction for power so this has to go to a good home.
Asking $850 shipped in CONUS....check my ratings, on RCU, RCG, FG, all good all the time!
