Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Everything Diesel
Venturi hole size for Irvine .40 conversion?
Everything Diesel Discuss R/C Diesel engines here.
Old 05-24-2023, 09:33 AM
franchi
Default Venturi hole size for Irvine .40 conversion?
I want to convert an Irvine .40 RC to CL use. What size of hole should I drill for the venturi if I plan on using an OS nva?
How could I use the existing RC carb for CL use?
Tia,
Franchi
Old 06-02-2023, 05:24 PM
Ployd
Hi Franchi,
The simple one first, if using the r/c carb just wire the throttle fully open and regulate the fuel flow with the main needle like you would with a regular glow engine,
If the intent is to fit a venturi with a straight through spray bar and needle set up then a venturi hole about 5/16" diameter where the spray bar goes through would be a good starting point.
Ployd in OZ
P.S. there is a venturi chart on the Barton Control line site that would give you a better answer.
Contact Us - Manage Preferences - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service -
