OS 46 AX - Prop Driver is Binding
My engine has been sitting on a bench for a couple of years so naturally it was a bit gummed up. I managed to free up everything to the point that it would turn over easily by hand - just turning the shaft with the plug out. However, when I put a prop on and tighten it up, I can't turn it at all. It looks like the prop driver (drive hub) is binding on the front of the engine. I did crash this engine nose first which is why it's been on the bench.
So, I'm wondering what damage I may have caused and what I can do to remedy this problem. Any good advice appreciated.
Remove the glow plug with the prop on, see if it turns over easily or not.
If it free up with the glow plug out then you have fluid in the engine,
If it is still seized with the glow plug out it looks like you have frontal damage from the crash.
Question is how to fix it. A small shim between the engine and prop driver ???? New bearings ????
Take it apart to make sure the crank is seated all the way in the bearings. Just tightening the prop might not have enough force to pull the crankshaft out if it's not all the way through the bearings. Might have rusted setting all those years.
Is the black thrust washer installed behind the prop driver and in front of the bearing, this is a common fault when the prop driver is removed that this thrust washer falls off and is not noticed.
