TopRC Model Voyager
TopRC Model Voyager
Top RC Voyager 128" Sport Jet
Length: 128 in/3253mm
Wing Span: 110 in/2790mm
Turbine: 18-22kg
Full composite construction
All surface prepainted, decals applied, and clear coated.
Scale cockpit included.
The detachable main wing, fuselage, and tailplane & vertical fin for easy transportation.
Removable hatch on the fuselage for easy access into the plane and change accessories.
Functional flaps for a smooth landing.
High-quality CNC Alu push rod included.
More than 95% assembled completely in the factory.
Tail tube and fuel tank included.
CG is 290MM from the leading edged of the wing at the root.
Selling my Top RC Voyager. Has JR S8931's on the elevators, JR 8911 on the rudder, Futaba S9177's on the flaps, Hitec D951TW on the ailerons, and a Hitec HS-7954SH for the nose wheel steering. All high voltage set up. I also have an extra set of mains and nose gear for spare parts.
Asking $5200 for airframe with gear, servos, gyro, stab bags, and spare gear parts.
Local pick up only, willing to drive about 2 hours distance to meet. I can also deliver to the IMAC NATs the end of July.
Turbine: 18-22kg
