Walbro WT 903 replacement
My Feedback: (19)
Does the original carb use internal pressure pulse or is there an external pressure line?
You should find a number of carb choices at Valley View RC, Mile High RC, etc. Any modern carb for that size engine should work as long as it has the proper pressure configuration.
IL
extra info:
I have a ( at best ) 53cc CRRC twin, it is made using 2 of there 26cc pro jugs and pistons so how they got to 55 I would like to know
unless the carb has been damaged, clean and replace the regulator diaphragm will fix wt type carbs 98% of the time ( how to vibs ).
Walbro WT carbs have the venturi size cast in 64th on the venturi itself, in this case 34.
Still can't find my reference chart for walbro.
