DLE 20RA Overheating
Old 07-19-2024, 04:38 PM
Red Baron Mike
My Feedback: (287)
Red Baron Mike's Avatar
Default DLE 20RA Overheating
Anyone have issues with the DLE20RA overheating since the rear muffler blocks the air from flowing cleanly through the fins?
Old 07-22-2024, 06:56 AM
LuvaraAir
LuvaraAir's Avatar
Do you have telemetry on cylinder head? Is it cowled? If so, what the does the inflow/outflow look like?
How long does it happen in the flight? Or is it on the ground?
It's pretty common for the DLE55RA to need a heat shield between the carb and muffler. 20RA might be the same and the carb is getting heat soaked.. It will act like the engine leans out.
Attached is an example I have on my 55's. A piece of .032 aluminum bent and attached between the muffler and cylinder head.
Old 08-14-2024, 04:47 PM
Red Baron Mike
My Feedback: (287)
I have two DLE 20 side exhaust engines, one to use on a TF .60 P-51 ARF. I did not buy the 20RE because it looked like an "overheating" issue waiting to happen (same with the DLE55RE), even though it would have been a much better match for the Mustang.
I was only asking to confirm whether or not this is an actual problem with these "RE" engines?
Old 08-17-2024, 05:56 PM
Truckracer
My Feedback: (19)
The rear exhaust engines cool just fine with a bit of baffling on each side of the cylinder. A heat shield between the muffler and carb is always a good idea. I just use a flat aluminum plate attached to the firewall by any convenient method.
Old 09-03-2024, 12:04 PM
Red Baron Mike
My Feedback: (287)
