Kingtech K-45 G4
Kingtech K-45 G4
Greetings,
I have an essentially brand-new K-45 G4 turbine for sale. The turbine was mounted in the inboard right nacelle of my B-58 Hustler and was test run. Total time on the turbine is 7 minutes and the turbine has 4 cycles. To get the turbine to fit into the nacelle I needed to trim the "clamshell-type" standard engine mount and replace the fuel inlet fitting with a smaller fitting. Both of these items can be replaced by buying replacement parts (less than $50 total) from Kingtech. Videos of the 4 cycles can be seen on my Facebook page.
Kingtech sells the turbine for $1690 US. I am selling the turbine complete (turbine, ECU, GSU, fuel filter, fuel pump, 90-degree manual shutoff valve, and the turbine manual for $1000 via Paypal (though other payment methods may be used. Email me at [email protected] for pictures of the turbine/ECU/GSU.
Regards,
Jim
Regards,
Jim
