E-flite Adhesives
E-flite Adhesives
Just curious, anybody know what the adhesive is used on E-flite planes? It has a rubbery consistency and seems to do a good job of holding things together.
I do not know which glue they use, but it does well when they apply enough. I and my friends have had instances with E-flite planes in which insufficient glue was applied... especially for servos, fixed landing gear mounting boxes and retract gear units. That said, I suspect it is something similar to Foam-Cure as marketed by Bob Smith Industries. See it at https://www.bsi-inc.com/hobby/foam_cure.html If you are trying to repair EPO foam, then I suggest Foam-Cure. It is rubbery, dries clear and is flexible enough to hinge foam flight control surfaces to the main structure. I have successfully repaired major crash damage on my E-flite Extra 300 with Foam-Cure.
