Will this work????
Will this work????
Will this radio work a collective pitch Micro Heli.... Like say I buy a Hummingbird and add collective pitch kit to it.....
hitec flash 5 system x
Flash 5 System X
Five channel FM aircraft computer radio
Looking to get the most out of a radio without spending most of your money? Then take a close look at the Flash 5 System X computer radio system. With high dollar features, such as five model memory, digital trims, “AutoSave”, 3 special flight modes for sport, electric or sailplane models as well as all of the most popular mixes, no other radio can touch the Flash 5 SX for quality and value. The Flash 5 SX is available in either a standard version with the deluxe HS-422 servos or as a micro system with the small HS-81 servos.
Features
5 Channel Microprocessor Design
5 Model Memory, Digital Trims
Mode I Or Mode II Capable, All Channel Servo Reversing
In-Flight Timer And Alarm, Low Battery Warning
End Point Adjustments For All Channels
Exponential Rates On Channels 1, 2 And 4
Data Reset To Defaults, Flaperon Capable
Auto Engine Cut Switch, Trainer Jack
3 Pre-Set Mixes, Aileron - Rudder, Elevon, V-Tail
3 Flight Modes, Acrobat, Glider And Glider/acro
Channel 5 Retract Switch, Camber Adjustment
Dual Rates On Channel 1 And 2, Proportional Flaps On Throttle Stick
Electric Motor Controller 3 Position Switch
Channel 1 And 5 Are Used For Two Ailerons Servos Allowing For The Use Of Very Creative Flaperon, Spoileron And Camber Or Reflex Mixes
Thanks for the help guys!
Flash 5 System X
Features
Do you know what gyro to get to the heli? If you can set remote gain on it you better go with a 6 or 7 channel radio since that function requiers an extra channel.
I can highly recommend Eclipse 7 from Hitec myself
I do not have a collective heli, but I do have two Hitec Flash5X's. To my knowledge, there is no way for this TX to mix three channels together to control cyclic and collective on a swash plate supported by three direct linkages. The 5th channel is a three position toggle switch, the center position is fixed and you can set the two end points.
The programming modes are "Glide, Acro, and Glide/Acro", all fixed wing oriented. Heli mode is conspicuously missing.
My previous reply was with reference to 120 degree swash plates. I just looked at the site for Precision Model Products (PMP) and see they also have CP swash plates with a "pitch slider" for the Piccolo. Using this scheme, the Flash 5x might work with rotor speed on the Ch5 toggle switch.
