Fuel line exits
My Feedback: (9)
Fuel line exits
For fuel proof fuel line exits: Drill the holes in the firewall slightly larger than the fuel tubing...Tape the holes on the back side of the firewall and fill the holes with epoxy...Drill out the holes slightly smaller than the tubing...Cut a sharp point on the ends of the tubing attached to the tank and lube the ends of the tubing ...Reach through the holes in the firewall with a couple of pieces of inner ny-rod and insert into the tubing...Pull the tubing through the holes in the fiewall till the tank is where you want it.
Tom
Tom
