Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
Best 3D prop for a YS 63FZ?????
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 11-07-2003, 08:43 AM
dave_anderson
My Feedback: (47)
dave_anderson's Avatar
Default Best 3D prop for a YS 63FZ?????
Any suggestions for the best 3D prop for a YS 63FZ? This will be for a U-Can-Do 46.
Dave
Old 11-07-2003, 09:32 AM
tombob
My Feedback: (7)
Default RE: Best 3D prop for a YS 63FZ?????
Dave: Me and a friend of mine both have YS 63FZ's he has a UCD3D I have a Flip 3D we both us 13X4W APC Props, we hover at about 1/4 thottle and accelerate out of the hover for a good safety margin . We also use 30% heli fuel works very good with these motors ,the prop will work on YS 20/20 fuel also. Make sure you get the 13X4W underline W because they sell a 13X4 sport, or pattern that does not work. Remember now no more tail touching or they will put you in the AMA jail.[sm=spinnyeyes.gif] TomBob
Old 11-07-2003, 10:38 AM
ballistic1
My Feedback: (27)
Yup -got a flip w/ ys 63fz 13/4 wide apc is the perfect match for this eng. /airframe combo !
I run 20/20 also
I have little rudder left from a multitude of tail touches and happy to say no one has been killed !!!
but dont tell anyone as I dont want to see the AMA swat team show up where I fly !!!!
Old 11-07-2003, 01:07 PM
ChuckAuger
My Feedback: (12)
Another vote for the 13X4W. And be careful ballistic1, MI has a self appointed, self proclaimed "Safety Nazi" right here on this forum that has vowed to make it his duty to "drop a dime" on all tail touchers.
Old 11-07-2003, 02:20 PM
ballistic1
My Feedback: (27)
Thanks for the tip Chuck- is that like a soup nazi?
Frank
ProBro 272
Old 11-07-2003, 02:58 PM
shadowspring
APC 13x4w, and if you havn't used coolpower 30% heli before then you are in for a real treat. Acceleration is amazing.
Old 11-07-2003, 03:19 PM
ballistic1
My Feedback: (27)
I will have to try the 30% -maybe it would run a 14/4w APC the same rpm as the 13/4w????????????
I bet Chuck would know!!
Old 11-07-2003, 04:26 PM
m.gramling
My Feedback: (8)
m.gramling's Avatar
I like the 13x4W on my YS63. Transition is real good
I really didn't like the 14x4W. Transition wasn't as quick. But I am running byron YS 20/20
Old 11-07-2003, 04:37 PM
ChuckAuger
My Feedback: (12)
I'm like Mike..I didn't care for the 14X4W. If I ran it again, I'd use 30% fuel, I think it would help. I was running 20/20.
As far as 14" props go, I liked the Zinger 14X4 with the LE and TE sharpened and the airfoil on the front shaved down the same amount. The Zinger has about a 1/16" flat on the LE and TE. I'd shave that to a point then make the airfoil 1/16" thinner..don't touch the back. Then make the tips the same shape as an APC instead of square. The Pro Zinger 14X4 has a better shape, not sure about those blunt LE and TE's.
Old 11-07-2003, 10:42 PM
BasinBum
I've been using an APC 13x6 on 20/20 and it's been real good but, I happen to have a 13x4W in the wrapper and an almost full jug of 30% Cool from racing. I guess when I take out my newly rebuilt 63 (cracked the case in a mid air) I'll have to try this combo. Should be 70 and partly cloudy tommarow so the Sledge gets it's second day out!
Old 11-07-2003, 10:51 PM
ChuckAuger
My Feedback: (12)
The 13X4W doesn't really need the 30%..I get high 12's like 12.7or8K on 20%. That's wrapping up pretty good, but on a Sledge you don't need that max RPM much. 30% might get you over 13K...the YS says it'll do 15K without grenading.
Old 11-08-2003, 12:43 AM
BasinBum
I was getting 10G's with 20/20 and the 13x6 today, I'll have to see what the 13x4 does before going to the higher nitro.
I am getting a bit more vibration than when I had the 63 on a Somthin Extra and I know the crank is straight and the prop is balanced. It would hold 2000 steady on idle so I know the low end is good.
Is the lighter Sledge more prone to a little shakin than a heavier airframe?
Old 11-08-2003, 12:48 AM
ChuckAuger
My Feedback: (12)
Prolly...I always thought the front of the Sledge was about as stout as a fence post, But Dave Shadel (YS Factory Guy) has serious misgivings about running the .63 on profiles at all. That said..I've not had any trouble with them. Check the mounting bolts after the first couple of flights and let 'er rip.
Old 11-08-2003, 01:26 AM
BasinBum
Name dropper...next your gonna say you know Jeff Williams.
Old 11-08-2003, 07:31 AM
dave_anderson
My Feedback: (47)
Thanks fellas, ordered 2 of them today (APC 13X4W's)
Old 11-08-2003, 02:22 PM
blue ice
Can you guys give me a part # for this prop? The local hobby shop says they can't find one with a W(bunch of kids). Thanks
Old 11-08-2003, 02:42 PM
ChuckAuger
My Feedback: (12)
They are probably trying to find it on one of the big distributors list (Horizon, Great Planes.. etc.) I had the same trouble getting APC 9X10's at my LHS. My LHS was finally able to find the 13X4W after a bit of research..
Anyway, APC Page will give them all the info they need, or you can just order direct and take it to the LHS and show them!!
Old 11-08-2003, 05:42 PM
blue ice
I went to apc's website and I didn't see it there until I clicked on fun fly 3d props. There it was. I had to call them back with part#. Wonder if I will get a discount for doing the leg work? Dont think so. Thanks guys.
Old 11-08-2003, 05:51 PM
ChuckAuger
My Feedback: (12)
HHhhmmm.. I thought the link I gave took ya right to the 13X4W page, but as long as you found it, that's the main thing!
Old 11-08-2003, 07:23 PM
blue ice
Thats the same page I found Chuck. Thanks for the point in the right direction. Got the Sledge built thanks to your help .Still waiting for Jeff to send me the tail mod. I am about to give up and just build it off the plans I have.
Old 11-08-2003, 08:10 PM
ChuckAuger
My Feedback: (12)
I bet we can get you a tail mod sheet, let me ask around!
Old 11-08-2003, 09:14 PM
Dennis Tampa FL
Hey Chuck, You dont let the YS 63 run that fast do ya?
I think Dave at YS says 11500 is about the fastest to run safe and long term durablity for the engine.
Thanks, Dennis
Old 11-08-2003, 09:20 PM
ChuckAuger
My Feedback: (12)
Yeah, I let 'er rip. Dave has also recommended the 12.25 X 3.75 APC for this engine. That would turn some serious RPM static. The key is, don't run it that fast except for bursts. I run the .63 over 12K static and have never even needed to re-set the valves on any of mine..I've checked them, but they were still spot on.
Don't be afraid, just don' be hard on that left stick.
Old 11-08-2003, 10:12 PM
hroachen
hroachen's Avatar
I've been running the 14x4W lately. It's abit slow to spool up, but there's something about the way it makes the plane feel that I've liked. Better than the 13x6's I've run, anyway.
I put a couple of the 13x4W's on order at the shop today, I should have them mid-week. Can't wait to try them.
D
Old 11-08-2003, 10:13 PM
PaulSwany
My Feedback: (45)
PaulSwany's Avatar
Hey Blue Ice... PM me your address and I'll mail you a print of the tail mod....
