NEW THROTTLE ARM FOR G26
CAN ANYONE TELL ME WHERE TO BUY A METAL THROTTLE ARM THAT WILL REPLACE THE ONE THAT COMES WITH THE ENGINE ? THIS NEW ARM CLAMPS AROUND THE THROTTLE ROD RATHER THAN BEING HELD IN PLACE BUY A SET SCREW. THIS TYPE OF ARM DOES NOT NEED A FLAT FILED ONTO THE THROTTLE ROD .
RE: NEW THROTTLE ARM FOR G26
I had a similar question and thought the linkage for a front wheel might work if the shaft diameter matched. The set screw might be more positive.
the set screw requires you to make a flat onthe shaft. i finnaly remembered where i saw the clamp type arm. take a look. http://www.rocketcityracing.com/tek9.asp?pg=products
