Foam Wing Repair
Foam Wing Repair
Old 05-06-2002, 07:50 PM
bigjohnsonrc
Default Foam Wing Repair
Question regarding Foam Wing Repair:
I have a Duraplane trainer which has a foam wing and had an unfortunate engagement with a metal post, which resulted in a deep gouge in the leading edge, approximately 1.5 inches long.
Does anyone have any thoughts as to an appropriate filler? Am currently looking at Hobbico hobbylite filler or K&B Micro-Balloons filler.
I have another wing kit but would like to repair the original as a backup? I appreciate any thoughts that may be provided.
Old 05-06-2002, 08:20 PM
phughes
If looks do not matter to you use a business card and clear packing tape from Staples. Wrap the card over the LE and tape it down. I have seen and used this for a quick fix . . .It always lasts as long as there is no other structural problems. make sure you check the wing very closly, as a small crack may not be noticable. Good Luck!
Old 05-06-2002, 11:08 PM
Ed Smith
Cut out a rectangular section of the leading edge, enough to remove the crushed pert. Glue in a pice of blue or pink foam and sand the profile to match the rest of the wing.
Ed S
Old 05-07-2002, 01:25 AM
wbrian
You could use expanding insulation foam. available at almost any hardware store. I use it for lots of stuff including: holding battery packs, fuel tanks, filling holes - whatever it's great stuff!!
Old 05-07-2002, 02:53 PM
TopShelf
A related question.
I have seen references to "Blue or Pink" foam. What exactly am I looking for when I go to the hardware store? Insulation?
Old 05-07-2002, 03:45 PM
Ed Smith
Blue pink or even grey foams are different types of insulation foam. They all cut with a wire but are usualy heavier than white foam.
Be carefull of the expanding foam in the can. Even the low expansion type can do a lot of damage as it expands. It does need to be controlled. I squirted some into a molded wing once and the wing puffed up like a balloon.
Ed S
Old 05-08-2002, 03:14 PM
SoppyJoe
My Feedback: (59)
If you can't find the blue or pink foam, just cut a square chunk of soft balsa and glue it in the ding. Then sand it down to match the wing!
Just my .002 cents worth!
Happy flying,
Joey. :idea:
Old 05-10-2002, 01:38 PM
Russ Verbael
1.Fly at a field where there are no metal posts.
2. Aim high.
3. Fly slow
4. Use metal wing leading edges.
(good luck)
Russ V.
Old 05-12-2002, 05:08 PM
bigjohnsonrc
Thanks for all the good suggestions. We will bring the wing back to life. And a special thanks to Russ-by the way, I couldn't find Montana, Arizona on the map.
Old 04-14-2003, 01:42 PM
John M. Bigelow
Like was said a of foam and elmers polyurethane glue like wallfoam when cured. will expand 20 to 30 % CU
Old 05-27-2003, 05:15 AM
JW Walker
Fill it with lightweight spackling from red devil, available at most hardware stores, you`ll know its the right stuff when you pick up the tub. It does`nt weigh hardly anything. Let it dry sand it back to what it should look like. JW
