XXXNT factory settings
Old 11-10-2003, 06:15 PM
whitexj
Default XXXNT factory settings
Does anyone have the factory needle settings for the xxxnt?
Old 11-11-2003, 12:27 PM
freakasssticks
Default RE: XXXNT factory settings
I don't have the settings right at hand but, as far as I know (and recollect), the High Speed needle setting is 3 turns out, Idle Speed is 5 turns out. That's what mine is set to and it works great. Obviously you may need to perform some minor adjustments to that, but it should work for you.
Cheers!!
Old 11-11-2003, 02:48 PM
whitexj
thnks alot... ill give it a try.
Old 11-11-2003, 03:02 PM
Nitroaddict
Nitroaddict's Avatar
HSN - between 2-3
LSN - 2 turns out
from team losi -
Old 11-12-2003, 01:33 PM
freakasssticks
Those settings are correct as well, but if you check their Quick Start sheet, it will list different settings. I've tried both and found the settings on the Instruction booklet (included in this thread) to be far from ideal. Somewhere within those settings you should fine happiness. Just my opinion.
Good Luck!!
Old 11-12-2003, 04:58 PM
whitexj
cant remember, is the hsn the one on the front of the carb, or the one that does the fuel input?
Old 11-12-2003, 06:37 PM
RC10GT_53
ORIGINAL: whitexj
the one with the fuel nipple on it........ and does anyone know the settings for a Mugen MT12?
