Large model Turbine Engines
11-12-2003, 09:59 AM
Pilots -
whats wrong with using a P 160 and setting it to 12lbs ?
It sure would run a long time..........
Jackjet
11-12-2003, 10:55 AM
AB, CANADA
RE: Large model Turbine Engines
A couple of things that come to mind are that it is heavier than a 12 lb engine, and the residual thrust at idle is higher.
11-12-2003, 12:40 PM
Not to mention the really tight squeeze into many 12lb thrust class airframes!
11-12-2003, 02:13 PM
That'll be a very expensive 12 lb thrust engine......
11-12-2003, 10:32 PM
Bob:
Do you really want me to fly this[sm=spinnyeyes.gif]
