Snow Tires
RE: Snow Tires
Paddles!!!! The front ribs should work pretty well. When the snow is real packy and the truck and run on top of it, you could use the stock pin tires.
RE: Snow Tires
I made a set of snow chains for my old TMaxx and was thinking of making another set for my Savage. The TMaxx had the stock plastic shafts which didnt hold up very long with the added weight and traction - they worked very well though. I was able to climb hard packed snow piles that were impossible without the chains.
Just a thought.
Just a thought.
RE: Snow Tires
this should work well out in the snow.
http://h1071181.hobbyshopnow.com/pro...prod=PRO104300
http://h1071181.hobbyshopnow.com/pro...prod=PRO105200
http://h1071181.hobbyshopnow.com/pro...prod=PRO107400
