da 150 vibration
Old 05-12-2002, 04:44 PM
extra330
Default da 150 vibration
have had around a gallon through the motor
32 x 10 meyjzlick prop
zn spinner
ecessive vibration especially at idle
anyone come across the same
tony
Old 05-12-2002, 05:37 PM
shill
My Feedback: (22)
shill's Avatar
No problems on mine. Have you balanced the prop. I know they claim to be factory balanced, but they are not even close.
Tracy
Old 05-12-2002, 06:04 PM
Antique
Antique's Avatar
Default DA 150
Twins don't vibrate unless mounted on soft rubber mounts..Set the idle for about 1400 rpm....
I run engines on a Black and Decker Workmate..The twins hardly move it....
Old 05-12-2002, 06:06 PM
extra330
Default da150
forgot to say, the engine is hard mounted,
cannot get idle below 1400rpm
Old 05-12-2002, 06:17 PM
Diablo-RCU
If the low end mixture is set too rich, it may be missing on one cylinder causing it to vibrate. It's also a possibility that the crank was not assembled properly. A twisted crank would also cause vibration. But, it should be worse at high rpm.
Old 05-12-2002, 06:21 PM
extra330
Default 150
now you mention it,
when i tested the smoke unit,it was only coming out of one exhaust ,
when throttle is advanced it switches to the other pot,
3/4 throttle and above and perfect.
new to large gassers so you will have to forgive my ignorance
thanks again
tony
