Hummingboard
Hummingboard
A quick question about the hummingboard...
When i increase the throttle over 3/4, the light changes from the usual green to red (not alternating). The light returns to green when the throttle is reduced to less than 3/4. It does this also when the battery is running down (when full throttle is no longer enough to lift it).
What does this mean? Is it anything to be concerned about?
Cheers.
Cheers.
TN
RE: Hummingboard
This is normal. When the light goes red it is telling you it is at full throttle in the condition you are describing, even though you may have more stick left you are at maxium power. As the battery runs down it will require more power to operate.
