piccolo problem
piccolo problem
i have a piccolo fun and sanwa rd 6000. and am having a problem when i take of and start to hover after a minite it starts to spin and i can not control it. is there something i can do to fix this
RE: piccolo problem
That is often caused by the tail pinion slipping after it gets warm. Put a drop of CA on the end of the pinion wiere the tip of the shaft is exposed. Be careful not let any CA run into the motor.
Here are a [link=http://www.ikarus-modellbau.de/ubbthreads/showflat.php?Cat=&Number=138982&page=0&view=collap sed&sb=5&o=&fpart=1]few[/link] - [link=http://www.pgoelz.com/piccolo1.html]good[/link] - [link=http://www.dream-models.com/h/flying-index.html]links[/link] that should help get you going.
