Wing ribs
Old 01-02-2004, 10:57 AM
militaryman
Default Wing ribs
Does anyone have a diagram of how you make a wing rib?
Old 01-02-2004, 11:52 AM
shawnh
Default RE: Wing ribs
You just need a template for the rib you need to make then cutt it out of a balsa sheet. What plane are you making this rib for?
MinnFlyer
MinnFlyer's Avatar
It would depend on the reason you're making one...
Are you designing a plane that you want to build from scratch?
Are you trying to make a rib to fix a broken one?
Etc.
Old 01-02-2004, 01:42 PM
DBCherry
Really, the shape of the rib will depend on the airfoil you want or have. Flat bottom, semi symmetrical, symmetrical, under-cambered, Eppler, Clark Y....
Dennis-
Old 01-02-2004, 02:07 PM
CafeenMan
Are you talking about actually making the ribs or plotting an airfoil? If you're making tapered ribs, then the easiest way is to make a root template and tip template and sandwich ribs between them and carve and sand to shape. More to it than that, but it's long winded.
If you're making constant chord ribs then you can stack your blanks and use a band saw or scroll saw or do what I do and cut them out individually using a template.
How to make constant chord ribs
Old 01-02-2004, 05:13 PM
militaryman
thanks for that cafeen man it helped alot.
i am making my piper cub some new wings from scratch as the old ones were completely destroyed
by a strange gust of wind and a big tree.[:-]
Old 01-02-2004, 05:16 PM
CafeenMan
MilitaryMan - Yeah... that gust of wind comes through these parts sometimes too.
Old 01-03-2004, 01:07 AM
jessiej
[MilitaryMan - Yeah... that gust of wind comes through these parts sometimes too.]
The same gust comes through here as well. Strange meterological phenomenon. Also frequent.[]
Ribs for the cub will be much simpler than for a Spitfire or some such with no two alike[8D]
Jess
Old 01-03-2004, 10:54 AM
militaryman
i bet god has some wierd fat secretery who likes to create random gusts of winds
at people who are flying their aircraft. life isnt fair.
