Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Walbro needle valves How do you tell the difference?
Old 01-11-2004, 12:12 AM
mikenlapaz
Default Walbro needle valves How do you tell the difference?
[>:] Pull them out without noting the where to put them back. Did a search without success.
Could use an assist, Thanks
Old 01-11-2004, 12:25 AM
Antique
Antique's Avatar
Default RE: Walbro needle valves How do you tell the difference?
Closest to the engine is always the low speed and the thread is usually different...
Old 01-11-2004, 12:43 AM
mikenlapaz
Will go check the thread. thanks Can you tell by the diameter down by the tip also?
Old 01-11-2004, 01:11 AM
Antique
Antique's Avatar
Probably not, the thread is the easiest way, or take the spring off and screw it in until it bottoms out, you won't hurt anything unless you really crank down on it....
Old 01-11-2004, 02:55 AM
mikenlapaz
It is a sone deal..
I was asleep on watch, the diameter/thread is the key. This is the first rebuild for me and was surprized in the difference in Diaphragm - Surge (the one with the metal); they are more like condums than the potatoe chip that was in the carb!
It appears that the D20 and D10 diaphragms are the the same; did not have proper kit so could not replace the fuel pump diaphragm ( the tan translucent one). It appeared clean and no detectable wear.
Again thanks.
Old 01-11-2004, 10:42 AM
Antique
Antique's Avatar
The two types of diaphragms work equally well. the tan colored one is more resistant to the additives in gasoline.....
