walboro wt 603
DC
I have run my G26 with all different size carbs, from a WA 125 to a WT 176 to a WA 167..Anything that fits the bolt pattern and has the pulse hole centered between the bolt holes will work....They all work the same, there is no reason to use anything other that the stock WT645.....
RCIGN1...I have an old BME 3.5 and I need a carb and insulator...do you happen to know what jug was used on the 3.5??? or what Walbro model # I need. I have e-mailed Keith at BME but no answer...he may be busy but I figured if anyone will know it might be you.
Boss
Boss
